Programming Endpoints...
My Feedback: (62)
NJ
While I was programming a couple of 5945's this morning, I noticed that in the instructions it says to set the left endpoint let's say, and then push the UP/L button, then set the right endpoint using the DN/R button. Is it just my programmer, or do all of them program left and right endpoints correctly no matter which button is used?
My Feedback: (62)
NJ
Sorry Mike. I thought that when you programmed the left rotation endpoint you had to hit the U/L button, and the D/R button for the right rotation endpoint. Turns out it doesn't matter which of the two buttons you push [U/L or D/R] to program either direction of the servo.
