Hi torque servos?
I have 2 x 705MG servos opperating the steering of a leg in a large boat. The servos are opperating off a Y lead in a push pull set up.
The torque from the leg is over riding the servos.
Is there a servo available in the 25 - 30kg range that I can use as a single with push pull off the one arm?
Do you think this is the right direction to fix the problem?
Thanks for your time
Paul.
Paul.
