Hitec Servos in CG Sukhoi 26 1.20
I have the above mentioned 120 size Sukhoi.... Question is....
two HS 605BB in the wing for ailerons
one HS 645MB on pull pull for Rudder
two HS 77BB for elevators
2 batteries parallel connected 6.0v NiMh 2000mah on Futaba R127DF receiver.(seperate on/off swithches and charge jacks)
Is this an ok set up? Do I need a regulator?
Thanks for any help.
