Hitec Prism 7 Glitch
I purchased two Hitec Prism 7 radios back in 1997. One of the transmitters appears to have some kind of a glitch in it. The first plane it crashed was my Hobby Lobby Skimmer. At that time I attributed the spin into the ground to a wing tip stall common on that design. A bit later I was flying my new SimProp Acro 40 (The best plane I ever had). It accelerated and went into the ground. Right then and there I put two and two together.
Upon thinking about the problem I decided it was cheaper, from an airplane point of view, to just buy a new radio. The transmitter, like new, has been sitting in my trunk for years. Is it worth taking a chance on...repairing. Or should I just avoid it.
My other Hitec Prism has performed very well.
Thanks for any advise...
Will
Will
hi
sorry to hear about your problems with hitec. I have a prism 7 and an eclipse 7 and am very happy with both. absolutely no problems. how does it do on range checks? hitec is very good on customer service, the lcd went out on my prism 7 and they replaced it with no charge. have you talked to their service dept?
my experience with them is such that if I were buying a radio today it would be a hitec.
good flying
joe
good flying
joe
Thanks, for the reply. I'm an eletronic technician - Air Traffic Control equipment like radars and radios. When I realized I was having a problem with the radio it was under warrenty. However, I was afraid to have it fixed because there was no way of checking it. The problem is so intermitent.
It does fine on a ground check. Perhaps there's a chip that is sensitive to heat or vibration inside. Could be a cold solder joint. Could be in the RF module. Don't know... I'm just wondering how HiTec goes about fixing such a problem. Heck...I don't want to lose another plane...they aren't cheap. A radio is cheaper.
I've already replaced the radio with a Futaba that was on sale. I usually have 5 or 6 planes that I rotate flying. The Prism 7 has a 3 plane memory. I would not hesitate to buy another HiTec. Problems like this can happen with any product.
