Hitec 5125 problems
I have a Hitec 5125 wing servo which is stalling at about 3/4 travel of stick travel, it looks like it's hitting an internal mechanical stop.
My question is - (a) is this a common (QC?) problem on the 5125 and (b) has anyone managed to fix it by adjusting the internal pot mechanics? It's easy to do on Volz and other servos but I don't want to open up the 5125 (which involves removing the labels), and find that the pot is inaccessible or cannot be adjusted relative to the shaft.
The servo is new, because time is short I'm prepared to fix it myself rather than returning it.
Thanks in advance
- Mike
Thanks in advance
- Mike
Can we assume you have turned up the ATV or end-point adjustments? A Dual-Rate is not activated?
Have you tried the servo on another channel to verify the servo is the problem?
My Feedback: (31)
What about the programming of the servo. This is a Hitec Digital servo, therefore its programmable. Do you have access to a programmer? If so reset it and set the end-points to your needs. If not sounds like you'll have to return it to Hitec with a note or possibly your Hobby Shop can exchange it for you..
I was hoping that somebody might have opened upa 5125 to see easy it is to reposition and secure the pot to the shaft.
- Mike
