problems with hitec flash 5
IA
I'm having problems with my flash 5. When I turn the rudder to the left no problems but when I turn to the right there is very little movment from the servo. I tried adjsting the EPA with no success and thought linkage bidup but nope linkage is fine. I even tried a different servo but same results. So I went through and reset the transmitter but again same results. Any suggestions? Thanks for your time, Mike
IA
I tried that to push to the left and set epa and push to the right and set. One other thing, when I reset the transmitter and the epa goes back to 100% the movement to the left goes down but the movement to the right goes down even farther. At 125% at both sides I only have about 5 or 10 degrees to the right and full movement to the left. I'm stumbled and getting ready to send it back. Thanks for your time, Mike
