Servos for 1 1/2 lb fun fly plane
IN
Mike! I've got a 1 1/2 lb funfly plane with large surfaces. The power for this plane will be a Magnum XL-15A. I would like the best servos for this job. The target weight for the plane is 1 1/2 lbs. What is the smallest servo I can use on the throttle?
Victor
Victor
IN
Will the HS-55 for work for all the servos on this plane? Is the HS-55 designed for controlling a plane of this size? If not what would be the best to use?
Victor
Victor
