Eclipse 7 flutter only one two channels in QPCM mode?
My Feedback: (91)
MI
I have a brand new Tx. and Rx. fresh from the factory, after Hitec replaced my old one;
unfortunatly the problem is still here. My aileron and flap servos flutter alot when I attempt
to use them only in QPCM mode in all of my aircraft. A couple of planes have mixed servos
but the others have a combo of 425's and 605's. I've useing servos, batt. and Rx. and got
the same results, any input or just slowly returning the stick to center will cause flutter for
up to five seconds before it stops...(crashable indeed!). The guys at Hitec had no solutions,
so they replaced my Tx. & Rx. and guess what??? The same problem; any ideals????[&o]
My Feedback: (91)
MI
No I'm not using amplified extentions or Y-connectors....Maybe thats the problem?
Yes, there is no flutter if I use my PPM receiver in PPM mode.
