HS-225 on 6.0 volts- erratic
NC
I have just finished a UCD 3D .46. I put 225's in the tail for the elevators. I went with a 6.0 volt pack for the extra speed and torque. Before I connected the control surfaces to the servos, I programmed my radio to get the servos working in the right directions. As I went to test, the servos acted erratic. With the first, tiny input (one way) both elevator servos went from stop to stop and then centered. Both servos traveled about 180 degrees. One of the sevos actually stripped some gears. All of the other servos worked flawlessly (HS-635HB, HS425BB, HS-81). I tried the system with a 4.8 volt pack and the problem did not replicate. As soon as I use the 6.0 volt pack the problem shows up again. With the first input to elevator, both servos travel from end to end and then center. These are brand new servos. Any help would be appreciated.
Spoon
Spoon
NC
yes. They are on separate channels going through 2 standard 24" extensions. They are in a UCD .46 as elevators. As I understand it, the long cable run lessens any affect that a fully charged 6 volt pack 'could' cause. I did talk to someone at Hitec and they just said "Send them back. they shouldn't do that". So hopefully it was just a freak incidence.
Spoon
Spoon
My Feedback: (31)
ORIGINAL: Spoon-RCU
Spoon
Spoon
