crystals
IL
Mike can a futaba crystal be put into a hitic reciver? I dont know and do not want to trash a good rec. trying this .I have heard of people switching one way but it would not work the other if futaba will work in hitic but hitic will not work in futaba
thanks RON
thanks RON
Banned
No.
The use a different frequency multiplier factor. Never put a different manufacturer's crystal in an RX.
It won't work either way. (at least it shouldn't work... if it does its essentially a miracle)
(this one is asked so often... and I've seen the answer so many times... I can answer it.)
IL
I did not think they were compatible but I heard one of the boths telling how you could use the cystals one way but not the other . when I was out at toledo . I did not think it was possible thats whyI posted this question.
thanks ron
thanks ron
My Feedback: (31)
ORIGINAL: r pedley
thanks RON
thanks RON
YES, this will work without issue... Hitec and Futaba crystals are interchangeable in either direction... This is not a wives tale. It works and I have seen the data to support the claim. Additionally I have many RX's setup as such.
As with any radio changes perform an adequate range check and have it...
