HITEC CRYSTALS
HITEC CRYSTALS
MAYBE BUYING A PLANE WITH HITEC SUPREME RECIEVER #24 CRYSTAL.HAVE FLASH 5
WITH 2 PLANES ON IT #57 CRYSTAL.CAN I PUT #57 IN THE SUPREME WITH NO PROBLEM.
THANKS
THANKS
RE: HITEC CRYSTALS
Yes put a Hitec dual conversion Rx crystal # 57 in your supreme and have a ball, No worries. The only other consideration is to check with the seller and confirm that the Tx he used was either a Futaba Or Hitec. The supremes are made in both positive shift and negative shift as well as a seven channel selectable shift version. What is important to use your flash five is that the supreme is either the negative shift or the selectable shift version, Othewise it will be incompatable.
John
John
