HS-5475HB servo shaft slop
MO
I have two HS-5475HB on my Raptor 50 for the cyclic controls. The for/aft servo shaft has a bit of movement (slop) in it. The left/right servo shaft is pretty tight. I do not want this servo to go out on me. My question is:
What do you think is causing this slop? Is it the bearings or the servo case where the bearings mount?
I know it is under warranty but I do not want to be down while my servo if off being fixed. Please let me know on the best way to proceed and not be down from flying.
Larry
Larry
