Hitec RCD3500 Rx might be glitching....
My Feedback: (20)
VA
Mike,
I had a RCD3500 (ch. 30) in a GP SlowPoke ARF, and it seemed to be glitching... Seems to happen at level flight, about 1/2 throttle... when the glitch occurs... the throttle goes to idle, the elevator deflects down for a brief moment... My TX is a Prism7, 600mah hitec battry pack, hitec 425 on the elevator, 303 on the throttle, cirrus 70BB on the rudder, and 2 JR537's in the main wing... thte engine is a .40FX OS...
I replaced the RX with another one today, and I'm going to try flying the slowpoke today... maybe it's something else (switch, battery), but I think its the RX.
Has this been reported before?
Dennis
Dennis
Glitching can be caused by several things. If you determan it is the receiver you can send it in and we will repair or replace it for you at no charge.
Mike.
Mike.
My Feedback: (20)
VA
Mike,
It's not the RX.... It looks like my throttle servo was "buzzing", causing a weird feedback (glitch) to the elevator servo... Yesterday, with a different RX and battery, the Slow Poke glitched several times... so at that point I know it was not the RX... after about 30 minutes of playing around with the controls (on the ground) we were able to duplicate the glitch, the trottle servo buzzing (because I had the ATV set to high)... we adjusted the ATV to stop the buzzing, and the glitch was gone... Good day at the field
thanks for your help.
Dennis
Dennis
