Flash 5 Mode Conversion
Hi,
I have a Hitec Flash 5 radio that I converted from Mode 2 to Mode 1, This was pretty straight foward but I have a question regarding the digital trims, Do you have to change anything inside or with the software? I cannot give the transmitter any "up" elevator trim! (left stick) I can give full down trim (-100%) it just won't allow any positive trim. the Throttle stick has full trim capability (+/-100%) I am guessing this is something to do with swapping the Elevator and Throttle sticks??
Any help?
Patrick
Any help?
Patrick
My Feedback: (31)
RE: Flash 5 Mode Conversion
This technical information is well beyond our knowlwegde base. However it sounds like a software issue as the elevator stick and trim is associated with working around neutral verses at the low throttle end-point...
Contact Tony at Hitec Service, he maybe able to shed some additional info on the subject.
[email protected] or call (858) 748-8440.
I got a response from Tony today:
---- Original Message -----
To: 'Patrick Murray'
Sent: Thursday, September 23, 2004 4:37 AM
Subject: RE: Flash 5 Mode Conversion
Hi Patrick,
In one of the menus, you will find a screen that shows ST with a 1 or 2 above it. By using the cut button, make sure the number is 1. If this is an older unit your then must save it by going to the SA screen and pressing the cut button again. If it is a system X then you can turn off the radio and it is ready to go.
Regards,
Tony Ohm
Service Manager
Hitec RCD USA, Inc.
Ph: 858-748-8440
Fax: 858-859-2618
I did this and it worked perfectly. (I did notice the menu said SE - with the E missing the top line, not ST)
Patrick
Hi Patrick,
Regards,
Tony Ohm
Service Manager
Hitec RCD USA, Inc.
Ph: 858-748-8440
Fax: 858-859-2618
Patrick
