RC Car Radio control lost!
CA
I have little radio control over my rc truck as of yesterday. With radio on the controls are at best jerky up to 10 ' range and nothing past that. It acts like interference, but I have run in this area for months with no problems and I have the same results at another location a mile away and 24 hrs. later.
I have changed batteries and check all connections and looked for frayed or broken wires.
I also switched the 27.045MHz crystal with another cars 64MHz crystal and that didn't work at all in either car.
Do I have a bad crystal, and why didn't the 64MHz one work, are they too far apart in frequency????
Sorry for the newbie question.
CA
Nitro, so what should I check that I haven't checked.
Lack of range....I'm talking 10 feet with the antenna pointed at the car and even then the servo's are jerking.
So can I get different frequency crystals for this radio if I stay in the 27MHz range, so when I do have interference and can switch them?
Thanks Mike.
Thanks Mike.
What radio system and receiver do you have? What crystals are you using? If you are still having problems I would sent it in and we will check it out for you.
Mike.
Mike.
CA
But turned out to be a newbie problem, the new batteries I installed in the car turned out to have one bad one in the batch, didn't believe it until I stuck a ohm meter on it them. Simple solution to a newbie problem, next time I will look hareder at the batteries instead of just putting in new ones.
Thanks again.
Thanks again.
