To be honest, the EXPO set up in the Flash is not ideal. To do what you want you should set the D/R to 125% so when you engage the D/R Expo switch you get a 25% increase in travel with Expo. Use your EPA to get the exact travel you want at full rate.
Mike.
Mike.
