Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
HITEC Shift Selectable reciever
Old 08-29-2002, 08:39 PM
rvd
Default HITEC Shift Selectable reciever
I got this reciever here that i purchased a few days ago that didn't come with any instructions..
I am using a airtronics radio with it. My servos are hitec and all have been changed so the positive wire is on the outside for the old style airtronics.. How is this reciever wired? Where does the pos/neg wires go for the servos and battery pack.. And also where do i place the jumper with the 2 wires for my setup ?
Old 08-30-2002, 02:37 PM
MikeMayberry
MikeMayberry's Avatar
You will need to swap the positive and negative wires back to their origional position. That receiver is wired negative (outside) positive (middle) and signal. The jumper I beleive will be from the inside to the middle, if not... just swap it. You can't hurt it by having it the wrong way unlike the servos.
There are two types of R/C planes too....
The ones that have crashed and the ones that are going to...
Mike.
Old 09-01-2002, 12:50 PM
rvd
Thanks Mike for the info..
About that reciever... Usually when I work on my planes in the house with the radio and plane turned on I always get little gltiches with most of my recievers but ever since I installed that new Hi-tec reciever I haven't noticed any glitches at all in the house. Another thing that impressed me was that my plane ranged checked farther than ever before with the antenna down. Like 1 1/2 times the distance.. Just wanted to tell you.. Money well spent..
