Optic 6 hiccup...??
OH
Optic 6 hiccup...??
I use my Optic 6 with an electric heli and have been programming without trouble until yesterday. I had just used the Tx to "play" with the collective, and then shut it off. The next time I turned it on, the memory had been erased and the Tx battery counter had been reset. I ended up having to re-program the model in the Tx and then I saved a copy.
My question is, has anyone else had this happen and by saving a copy, am I safe against another "hiccup"??
CA
RE: Optic 6 hiccup...??
It sounds like your transmitter may have the model 1 reset software glitch. We have seen this ina few radios and are working on this problem as well as the other one that has been documented. This only affects model 1 so for now set up your models on memory 2-8 so it does not reset on you. As soon as the update is available to solve the two issues with thte Optic we will post this and take care of everyones radio.
