Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
555 RX / Airtronics Stylus Tx Problem
Old 09-14-2002, 03:52 PM
Wormy J
Default 555 RX / Airtronics Stylus Tx Problem
I have a 555 rx that I have been using with my JR Tx for a couple of years. I wanted to use my new Stylus with that Rx today but it does not work with this Tx.
Here are the facts:
Both JR and Airtronics on same channel (35)
Rx works fine with JR Tx
Modulation is correct on Airtronics ( not on PCM, on PPM)
The Airtonics Tx operates my Supreme 8ch just fine.
Swapped Tx using same module, same problem.
555 is "JR" version as are all or my other Hitec Rx's that I use with my other Stylus Tx.
I suspect that the 555 is unique in some way to not operate with this transmitter. Is this correct?
Jeremy
Old 09-16-2002, 03:07 PM
MikeMayberry
MikeMayberry's Avatar
It should work.
Mike.
