Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 Battery Rundown Results?
Old 03-05-2005, 06:43 PM
CFIMEI
Default Optic 6 Battery Rundown Results?
HI,
Just saw a thread in here where a Flash 5 user experienced self chew-up of an E-Prom when he accidently let his battery go flat. I assumed from that there is no under voltage write protect in that Tx? What about Eclipse & Optic. The chances of running flat in those are much higher than with Flash. ( I get 3 to 3.5 hrs on my Flash & 50 to 70 minutes on Optic.) If Optic should be inadvertantly left on am I faced with a service return or does it have protection to cleanly shutdown berfore it starts corrupting its own firmware?
Old 03-07-2005, 01:01 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Optic 6 Battery Rundown Results?
There are no know problems if the Optic or Eclipse battery is inadvertantly run down to zero.
Mike.
