Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
EPA >100%
Old 03-20-2005, 01:54 PM
Ian.W
Ian.W's Avatar
Default EPA >100%
Hi
I have some 6475s and a 6485 in my extreme flight RC Yak. the thing is with 3D i need to keep my mechanical advantage high, so i get no slop, thus no flutter so in the end my tail will still be attached to the plane. However, i cant quite get get the movements i like for 3D with the biggest supplied horn and 100% EPA. What sort of long and short term damage would i do for using 150% EPA? Note that i wouldnt use it all the time only for extreme 3D manuevers, some of which last for only seconds (e.g. a wall)
Ian
Old 03-21-2005, 11:21 AM
tohm
Default RE: EPA >100%
It is perfectly ok to run the EPA up on those servos. You should not experience and short or long term damage.
Old 03-22-2005, 03:40 PM
Ian.W
Ian.W's Avatar
thanks Tony!
