Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 throttle set-up
Old 03-21-2005, 12:25 PM
republic
Default Optic 6 throttle set-up
I just got my Optic 6 and so far think it's great. I am still setting the TX up for my aircraft and am having trouble setting up the throttle.
The manual say's to set throttle trim to +25% and that's were I run into the problem. My TX let's me set negative throttle trim, but when I push the trim lever up/forward nothing happens. Am I doing something wrong or am I missing a step. Any help would be great.
Old 03-21-2005, 01:09 PM
tohm
Default RE: Optic 6 throttle set-up
The throttle trim on the Optic can be set between 0% and -50%. You will only be able to set the trim when the stick is in the full down or off position.
Old 03-21-2005, 05:58 PM
XJet
Banned
Why is that?
Sometimes it's awfully nice to be able to change the trim while the engine is at something other than idle.
With my 3D ships I usually fly with a medium idle for most of the flight (so that there's no chance of it dying in hi-G manuvers with the throttle cut right back) but I do like to bring it down to a lower tick-over for landings. It's always *much* easier to tweak the throttel trim when you've got some power on rather than when you're *at* idle in such cases.
I also notice that on my E7 I can only adjust the idle trim with the flight-condition switch set to one position -- on the other positions the trim just doesn't work (the Optic 6 maybe the same but I'm not using the FC switch yet). Why's that?
Old 03-21-2005, 06:20 PM
MikeMayberry
MikeMayberry's Avatar
X-Jet- The throttle trim on most radios only works below 50% stick travel. This is so not to affect the high thottle end point.
In the future, please ask any new questions in a separate thread and try not to tag them onto exsisting posts.
Thanks!
Mike.
