Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec Flash 4X, transmitter battery
Old 04-05-2005, 10:42 AM
jkirby65
Default Hitec Flash 4X, transmitter battery
Hi,
I have a Hitec Flash 4X and have been using it for several years. The one thing I have been unhappy about is the length of time my transmitter battery keeps a charge. It never lasted very long, but now it lasts only enough for about 2 ten minute flights. Is this usual? I recently bought a new battery for it, but that did not help. This leads me to believe there is a problem with the transmitter itself. Everything else seems to work just fine, but the battery does not give me much time to fly. Help and suggestions are much appreciated.
Jim K
Old 04-05-2005, 10:50 AM
tohm
Default RE: Hitec Flash 4X, transmitter battery
If you or a friend has a battery cycler, test the batteries to make sure they are holding a proper charge. If they are, the transmitter might need to be calibrated, in which case you will need to send it in for service.
Old 04-05-2005, 12:49 PM
jkirby65
Thanks for the info. I have two followup questions. First, what rates should I discharge/charge the battery during the cycle? Second, how long does it take to service the unit (if cycling doesn't work)?
Jim
