Eclipse 7 flight conditions and idle RPM settings
I would like to have different (higher) idle RPM in different flight conditions with the Eclipse 7 in ACRO mode. I have activated flight conditions and programmed D/R and Expo for all of them. But the throttle trimm is working only in NORM mode. In ST1-2-3 the throttle trimm does not work. Can you recommend some work around?
Banned
I've encountered this too and when I asked here nobody answered.
*WHY* doesn't the throttle trim work in other flight-mode settings -- there would seem to be no good reason for it not to other than someone goofing when designing the software.
I setup a fast idle with the eclipse using a p mix. Mix channel 3 to channel 3 and set the % on one to around 15% for fast idle. I do my 3D with the fast idle on an then flip the switch to slow the idle to land.
Randy
Randy
