Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 Slave Channel Behaviour
Old 04-21-2005, 11:03 PM
CFIMEI
Default Optic 6 Slave Channel Behaviour
HI,
I am using PMX1 & 2 in order to effect a "flaperon" response while using ADIF. I have slaved each aileron channel (1 & 5) to elevator & have gotten the desired reactions in response to primary elevator inputs. But there appears to be no reaction by ailerons to trim inputs to elevator. I expected (& require) that the ailerons would follow elevator not only in main stick inputs but in pitch trim as well. I have tried other setups in CROW & FLPN ( with a 6 channel Rx) & found that trim fails to change ailerons here also. What is the deal??
CFIMEI
Old 04-22-2005, 02:00 PM
tohm
Default RE: Optic 6 Slave Channel Behaviour
In the Eclipse and the Optic, the master trim does not affect the slave. Unfortunately there is no changing this.
