Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
EVO 9 LED problem
Old 04-25-2005, 12:59 PM
highboy
Default EVO 9 LED problem
Hello guys !
I just bought a Evo 9 with Synth and scanner module.
My problem is that when the antenna is not extended and i turn on the radio, the red LED blinks as it's supposed to when the radio is transmitting a signal.
But If i extend the antenna, and turn on the radio (transmitting a signal) the LED is just glowing solid, even though it's transmitting a signal.
Then if i touch the antenna the LED starts to blink (Almost every time)
Is the radio broken and should i send it back for repair ?
My dealer here in Denmark does not know enough to help me.
Old 04-25-2005, 02:01 PM
tohm
Default RE: EVO 9 LED problem
This can be fixed by sending it in for service. The problem will not cause any issues while flying (range and the like) but could be annoying because it is hard to tell when it is transmitting.
Old 04-25-2005, 02:05 PM
highboy
Ok, do i send it directly to Multiplex in Germany or does it have to go through my dealer here in Denmark ?
Do i have to send anything with it ? when it has been bought and so ? (It's only a few days old)
You say it's nothing serious, but what causes the problem ?
