Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Expo on Optic
Old 04-27-2005, 06:54 AM
Vismund
Default Expo on Optic
Will expo also affect the slave channel when using flaperon/Spoileron/dual elevators on an Optic?
Old 04-27-2005, 08:43 AM
mglavin
My Feedback: (31)
Default RE: Expo on Optic
ORIGINAL: Vismund
YES! The channels and or servos are linked when the mixes are activated. Same is true for Trims, Rates as well as Expo.
Old 04-28-2005, 10:50 AM
CFIMEI
Hi,
When I asked this question I was told that trim changes are NOT followed by slaved channels & I know this is true with my Optic. Has there been a change in firmware that has fixed this?
CFIMEI
Old 04-28-2005, 11:16 AM
MikeMayberry
MikeMayberry's Avatar
When using all the dedicated mixing (I.E. ail diff, flapperons, dual elevator, v-tail, etc...) the trims will all work properly on each control surface; it's only the p-mixes where the trims don't link to the slave. This is also true with other manufacturers systems until you get into the real high end radios.
Mike.
Old 04-28-2005, 05:57 PM
CFIMEI
Hi,
Yes, the control surfaces will directly follow their respective trim inputs; e.g. both ailerons follow aileron trim (except in CROW), elevator follows elevator trim, rudder follows rudder trim. But try this: Enable FLPN & activate E>F with a useful % of elevator to flapperon (ail) coupling. Then input some elevator trim. You will find ( if the same TX is being discussed) that the elevator will respond to that trim but not the ailerons, in unison, which are slaved to it when in FLPN mode. I think you are implying that they will. You may want to reconsider this when advising others.
CFIMEI
Old 04-28-2005, 06:10 PM
MikeMayberry
I didn't imply that at all... In Flapperon mode the aileron trim affect both aileron servos. These are two control surfaces in Flap/Elev mixing so the trims should not link. The same holds true for air/rud mixing.. the user has to trim each individually. Trims will link where two servos are use for one function like ailerons, V-tail, and Dual elevator. You shouldn't have the flaps move when you trim the elevator in Flap/Elev mixing. This holds true in other manufacturers radios as well.
Mike.
Old 04-28-2005, 06:22 PM
CFIMEI
Hi,
Do you know what "obfuscation" or "conflation" means?
CFIMEI
