Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec servos 4-1
Old 05-11-2005, 07:44 PM
longeze
My Feedback: (9)
longeze's Avatar
Default Hitec servos 4-1
Have four Hitec servos, 2-HS-5645 and 2-HS-5625 running out of one lead to reciever for flaps on a Ziroli P-38. Everything works fine, all servos programed to work together. Some attention was brought to me about the possibility of this being a bad thing to do. I'm using a JR system with a PCM reciever. Am I ok!
Old 05-11-2005, 08:04 PM
lrb75
My Feedback: (12)
Default RE: Hitec servos 4-1
Why would you use two different speed and torque servos for the flaps?? Technically it should work if you have the throws and the speeds programmed correctly, but under load the 5645 should deploy faster than the slowed down 5625 due to the better gear ratio. I hope you have 1 5625 and 1 5645 on each side.
Old 05-11-2005, 08:09 PM
longeze
My Feedback: (9)
longeze's Avatar
THe 5625s are on the outboard wing flaps which are smaller and the 5645s are on the inboard flaps which are larger.
Old 05-12-2005, 09:15 PM
longeze
My Feedback: (9)
longeze's Avatar
Was this answered by manufacturing support ?
