Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
New Qpcm receiver acting strange
Old 05-26-2005, 09:09 PM
BAS
My Feedback: (28)
Default New Qpcm receiver acting strange
I recentily purchased another Qpcm receiver for my Texas Hurricane. I had another one in the plane and took it out for a nother project. Today when i hook all my servos back in the new receiver on the elevators which are 645 s hook with a y and the alerons when the servos center they chatter and bounce up and down for a second then settle down. I have never had nor had this problem with the other identical reciever .I tried all the usuall things to isolate the problem , bypassed the switch , rerouted antena, changed shifts on the radio and you name it i done it. Any ideas of what could be causing this glitch. The servos act up when the motor is not running or running.
Old 05-26-2005, 11:04 PM
mglavin
My Feedback: (31)
Default RE: New Qpcm receiver acting strange
What voltage battery?
Is the problem realized fresh off charge or anytime?
Do you have some additional servos to test the RX with outside the model?
New crystal? Hitec crystal?
Lastly its possible the RX is the problem.
Old 05-27-2005, 05:16 AM
BAS
My Feedback: (28)
6 volt batt 3800 nimh batt was run for 30 minutes still glitching after the fresh charge Newer eclipse radio brand new receiver with correct crystal hitec, i just hooked up two brand new 645 servos outside the plane using a new y lead still having the same problem , servos glitching and chattering for about 3 to 5 seconds before settling down. Must be the new receiver. ????
Old 05-27-2005, 06:38 AM
Cub Man
My Feedback: (50)
Cub Man's Avatar
I have the same thing going on with a rudder servo but have not had time to run any test on it as of now.
Old 05-27-2005, 07:36 AM
mglavin
My Feedback: (31)
After the servos settle down from the initial power-up all is well?
Old 05-27-2005, 07:37 AM
mglavin
My Feedback: (31)
Old 05-27-2005, 08:11 AM
BAS
My Feedback: (28)
No as soon as i start moving the sticks again the servos still chatter and move irractic . I just switched out the receiver when my other qpcm receiver everything works ok with it so it has to be the new receiver will send it back to Hitec.
