Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec Challenger 720 Receiver Question
Old 06-08-2005, 07:51 AM
niterdr
Default Hitec Challenger 720 Receiver Question
Some years ago I bought an Aristocraft Hitec Challenger 720 Radio System to convert it to a ground frequency (Channel 82) to be used in a scale model boat. I built one of the ACE RF kits and Receiver to use with this radio. As this was the beginning of FM radios I would believe that the RF Module would not be different from the original in transmitting only in Frequency. What I would like to know is in todays receivers (Single Conversion, Dual Conversion, +shift, -Shift) what would be compatible, would a Hitec -shift FM receiver work with this Radio?
Alex Gray
Old 06-09-2005, 04:22 PM
tohm
Default RE: Hitec Challenger 720 Receiver Question
If the unit is on a ground frequency, you would want either our Supreme 75MHz, the DCX or the HFS-03mm. All the above are negative shift.
