Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec 5645s and Airtronics PCM??
Old 06-13-2005, 01:14 PM
PlagueWielder
Default Hitec 5645s and Airtronics PCM??
Hey
I need to know if there are any problems with these servos. Im going to run 5 of them in an EF Yak with an 8 channel PCM Airtronics reciever. 4 of them will be on extensions, 2 will be 12" and 2 will be 24".
Anyone heard of problems with these servos combined with extensions? I will not have any Y's... everything seperated. And does anyone know if there are problems with combining these servos with the Airtronics reciever (similar to the Futaba problem...)?
Thank you
Old 06-14-2005, 12:37 PM
tohm
Default RE: Hitec 5645s and Airtronics PCM??
No known issues when using those servos with the Airt. PCM receivers. Even if the signal voltage of the receiver is low, it will not affect you since you are not going to use a y-harness.
Old 06-14-2005, 12:40 PM
PlagueWielder
Thank you.
Can you please recommend a good battery for the servos (6V)? Will something like 1700 mAh be enough or should I go for more?
Old 06-15-2005, 01:33 PM
tohm
A 1700 or a 2000mA pack would be fine.
Old 06-15-2005, 02:45 PM
PlagueWielder
Thank you.
