Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Tx battery disconnect and memory Question
Old 07-03-2005, 03:39 PM
440GTX
Default Tx battery disconnect and memory Question
How long can you disconnect the battery from my Eclipse 7 Tx
before the programming memory is lost ?
I would like to cycle the battery .
My soldering sucks so I did not use diode cross trick.
Thanks in advance
Fred..
Old 07-06-2005, 12:35 PM
tohm
Default RE: Tx battery disconnect and memory Question
The Eclipse uses a EEProm that will retain it's memory for 10 years if disconnected.
