Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Glitches after battery charge
Old 07-05-2005, 06:18 AM
scott14
scott14's Avatar
Default Glitches after battery charge
I'm experienceing something I've never seen before.....
Brand new setup:
Hitec Electron 6
HydriMax 1650Mah NiMH battery
JR 9303 transmitter
Futaba 9303 servos
After charging the battery (NiMH 1650) when I turn on the transmitter it starts to twitch, and the controsl are not functioning correctly. What I see is when moving the throttle up ALL the control surfaces move, like it was mixed together? The control surfaces work independantly, but are VERY SLOW!!! I turned off everything..... moved to another area at the field, and the problem went away.... moved back to my flight station and the problem was gone...... I fueled up the plane, topped off the charge, and then the GLITCH WAS BACK!!!!
Now I'm at home trying to figure out the problem, but the glitch is gone.... It only appears to happen after I charge the battery?????
Any idea's....
Old 07-06-2005, 12:44 PM
tohm
Default RE: Glitches after battery charge
Have you tried another receiver to narrow down the problem?
Old 07-07-2005, 06:49 AM
scott14
scott14's Avatar
I had another new Electron 6, and tried it last night. Problem solved.
I'll send the bad one in for service.
