Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Multiplex Cockpit MM - Combat Wing settings
Old 07-21-2005, 08:00 AM
alecphilpott
Default Multiplex Cockpit MM - Combat Wing settings
Hi,
I have just replaced my Futaba 6EXA with a Cockpit MM (more model memories etc).
My combat wings are currently set up with the servos plugged into Channels 1 & 2 on the RX.
I have told the TX that I want Delta mixing, but the following happens:-
1) the elevons work correctly when I move the elevator stick
2) only one servo moves when I move the aleron stick
I note the manual says something about elevons being output to channels 1 & 5, but I only have 4 ch RX's - is there any way around this?
many thanks
Alec
Old 07-22-2005, 03:22 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Multiplex Cockpit MM - Combat Wing settings
Unfortunatley we have limited experience with this radio here at Multiplex USA since we only ever sold a handfull of them. It looks like you are going to need a 5CH rx.
Mike.
Old 09-05-2005, 07:31 AM
alecphilpott
It turns out you can do it! Use V Tail mixing (uses Channels 1 and 3) and change the setup to Mode 4. Hey presto!
I cant understand why they were not a popular model - it blows the Futaba away!
