Screws on HS-50 are too small!!!
WA
I'm working with the HS-50's, and the screw is in really tight this time, I'm using a #0 phillips head screwdriver, and I'm only stripping the head, so It's near impossible to change the horn to the size I need... Make the phillips head bigger like on the JR 241's! Please! And, use a much higher quality metal, it strips way too easily. Sorry that this is a rant, but seriously, it needs to be addressed! This is a problem with other servos such as the HS-55, HS-56 etc. Thank you for your consideration.
