CG-330 questions
CG-330 questions
Dear Mike,
I have a few questions on the CG-330 :
1) What is the trickle charge current for the glow charger ?
2) What is the trickle charge current for 4-24 cell charging ?
3) Can I use my car 12V battery rated at 50Ah as the source ?
4) In the manual it says that the input battery minimum capacity is 10 A. Is this suppose to be printed as 10Ah ?
5) Is there any fuse inside the charger ? If there isn't I would like to install one outside the charger (built into the cigarette lighter plug). What fuse rating should I use (how many amps) ?
Sorry for asking so many questions. Thanks for the good support.............
CG-330 questions
1. 1.1A
2. .05 -.5A depending on the amp setting
3. Yes
4. 10 Amps
5. There is no fuse. It has built in reverse polarity protection
6. You don't need a fuse.
Mike.
3. Yes
4. 10 Amps
Mike.
CG-330 questions
Dear Mike, Thanks for the reply ! On your answer to question (1), 1.1 A as trickle charge for the glow charger is kinda high. The manual says that 1.1A is the full charge current. Could you kindly confirm what the trickle charge rate is ? Thanks again..........
