Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Flash 5 w/ three channels
Old 11-16-2002, 01:57 AM
diser
diser's Avatar
Default Flash 5 w/ three channels
I just got a Hitec Flash 5 and i also have a 3 channel airplane w/ throttle, elevator, and rudder and i was wondering how i could get it so both the rudder and aileron sticks controlled the rudder
Old 11-17-2002, 12:08 AM
JohnBuckner
JohnBuckner's Avatar
Default Try this
Diser with that radio and a three function airplane that you want both sticks to operate the rudder and not use the fourth servo, this will work. Plug the rudder servo into the channel #4 port as usual, nothing is plugged into the channel #1 aileron port. Now enable rudder to aileron mix (which is avaliable on this radio) follow the manual for this pre programed mix and set the mix at 100% which will allow both sticks to move the rudder at the same throw without the need to have anything plugged into the #1 aileron port.
If you use End point adjustments or on the rudder you will need to setup the same endpoint percentages on Channel #1 also to get the same response from either stick. You can also use dual rates on the ch #1 stick but only on the right aileron stick since the Flash 5X does not support DR on the CH #4 rudder stick.
John
Old 11-18-2002, 05:20 PM
MikeMayberry
MikeMayberry's Avatar
diser- I don't know why you would want to do this. I would just plug the rudder into channel 1 since you will want to operate it with your right stick, not the left.
Mike.
Old 11-18-2002, 10:03 PM
JohnBuckner
Mike sorry for popping up on this one and not sure what Diser's reason is but doing this for some protracted glider flights is very handy to change thumbs a little for directional particularly when you are reclining for for along period.
John
Old 11-18-2002, 10:14 PM
diser
diser's Avatar
Default the reason
the reason is this i have always steered on the ground with my right hand and in the air with my left and i would hate to be at full throotle on the ground and try and steer with the wrong hand
Old 11-19-2002, 04:52 PM
MikeMayberry
Fair enough!
