Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
555 RX. Question...
Old 11-18-2002, 09:25 PM
proptop
My Feedback: (8)
proptop's Avatar
Default 555 RX. Question...
Hi Mike, this time I have a question from a buddy of mine who doesn't have a computer. He's gonna build a plane w/ retracts, it takes 2 ret. servos, plugged into a Y- harness, then into the batt./5 socket... He (we) want to know where do you then plug in the batt./switch conn.??? Thanks again! Tom... P.S. I mailed my Flash 5 tx. + 535 rx. Fri.(15th.) You should receive it soon. Can you put in a new ch.28 x-tal in the 535(just in case) and enclose annother on ch.22 so I can also use the Flash tx. if desired? Thanks, once more.
Old 11-18-2002, 09:29 PM
MikeMayberry
MikeMayberry's Avatar
If all channels are used then he will need to use a y-harness in any of the channels to plug in the battery.
Mike.
Old 11-18-2002, 09:46 PM
proptop
My Feedback: (8)
proptop's Avatar
That's what I thought, thank's again, Mike!
