Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Programmer
Old 12-04-2002, 02:03 AM
Banker
My Feedback: (10)
Default Programmer
When you set the center point at something other than zero, do the end points need to be adjusted using the same offset? Example: center point at -3 to get the same throws do the end points need to be -197 and 203?
Old 12-04-2002, 04:32 PM
MikeMayberry
MikeMayberry's Avatar
Default Programmer
Yes.
Old 12-04-2002, 05:58 PM
willembad
Default Huh????
Hi,
I've never used a programmer, but using your example, the math seems incorrect. If -3 is center then it is 194 steps off of -197 and 206 steps off of 203.
I think (and apparently so did Mike ) that you meant endpoints of -203 and 197 for a -3 center.
I'm I confused enough yet?
Willem
Old 12-04-2002, 06:27 PM
MikeMayberry
Default Programmer
Details, details....
Old 12-04-2002, 06:40 PM
Banker
My Feedback: (10)
Default Programmer
Yeah. Your correct, just got my sides wrong. Thanks.
