Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Charging HFP-10 Programmer
Old 12-19-2002, 01:58 PM
Chuckr53-RCU
My Feedback: (40)
Default Charging HFP-10 Programmer
Mike,
I have a Hobbico Accu-Cycler. Am I safely charging my programmer using the 125 setting instead of the 50 setting on the Rx side? I know the Accu-Cycle will charge for 15 hours, so the 50 setting will not fully charge the programer's battery pack, but I'm concerned I'll damage the pack at the 125 setting.
Chuck
Old 12-19-2002, 02:02 PM
Chuckr53-RCU
My Feedback: (40)
FYI...I started charging at the 125 setting then after thinking about it, I flipped the setting to 50 after the first 6 hours. I don't think I caused any problems, but thought I'd try and get some informed help from "the source."
Old 12-19-2002, 04:32 PM
MikeMayberry
MikeMayberry's Avatar
That shouldn't be a problem.
Mike.
Old 12-19-2002, 04:46 PM
Chuckr53-RCU
My Feedback: (40)
Which shouldn't be a problem...125 setting for the whole time or 6 hours @ 125 then 9 hours @ 50...or either?
Sorry, I just don't want to screw up the batteries or the programmer.
Old 12-19-2002, 05:47 PM
MikeMayberry
Doesn't the Accucycle have a peak circuit to shut off when the battery is charged?
Mike.
Old 12-19-2002, 06:38 PM
Chuckr53-RCU
My Feedback: (40)
I don't think so...the manual doesn't mention one. It only mentions timing the charge for 15 hours.
Old 12-19-2002, 08:21 PM
hilleyja
Mike.
Mike, the Hobbico Accucycle is a timed-charger, not a peak charger. The Accucyle-Plus is a peak charger.
Old 01-01-2003, 10:55 PM
Chuckr53-RCU
My Feedback: (40)
Mike...any more info?
Old 01-02-2003, 08:46 AM
Mr T.
As I understand the HFP-10 has a 1100 mAh pack in it, so 125 mA setting is just a tad over C/10 charge rate which should charge the pack in 14 hours. At C/10 rate no damage can occur even if you leave it on for more than 24 hours. Don't worry.
Old 01-02-2003, 11:22 AM
Chuckr53-RCU
My Feedback: (40)
thanks
