Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Hitec HFD-08RD Reciever with a JR 2610 Tran
Old 06-09-2006, 05:32 PM
krammer
Default Hitec HFD-08RD Reciever with a JR 2610 Tran
Hi,
I have a Hitec HFD-08RD RX and want to use it with a JR2610 TX is this possible as i see a lot of talk about negitive shift and positive shift,
If it is possible can some one tell me how? as i have tryed it and as soon as you plug the battery in the servos go all grazy and only work when the radio arial is right beside the reciever arial.
Thank You
Old 06-09-2006, 06:20 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Hitec HFD-08RD Reciever with a JR 2610 Tran
What band?
Mike.
Old 06-09-2006, 06:33 PM
krammer
IT is a 36MHz
Old 06-10-2006, 09:05 AM
mglavin
My Feedback: (31)
What does the RX state on the case label, for use with Futaba or JR?
JR-MPX-Airtronics require POSITIVE shift while Futaba-Hitec require NEGATIVE shift RX's.
Sounds like you have a NEGATIVE shift RX.
You must have the TX setup for PPM modulation as well..
