Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
programer EP question
Old 06-09-2006, 08:32 PM
flyrccg
My Feedback: (25)
Default programer EP question
I just got a programer and set the neutral and endpoints for my 5955's. When I hook up to my rec. and test with my JR 8103, I'm only getting about half of the throws programed even with my radio travel set at 150%. HELP!!!
Old 06-10-2006, 08:54 AM
mglavin
My Feedback: (31)
Default RE: programer EP question
Use the programmer in the manual servo test mode and see if the servo(s) will move as far you desire and or programmed them... If not it maybe a programming error or possibly the TX is to blame. If they move as programmed it has to be the TX.
Old 06-10-2006, 07:04 PM
flyrccg
My Feedback: (25)
It moves as programmed in the manual mode. Have you ever heard of this problem before? Any suggestions?
Old 06-10-2006, 07:46 PM
mglavin
My Feedback: (31)
Sounds to me like the TX is not out putting the proper control signal to move the servos to the commanded position. Is a low rate switch active? Bottom line is if the Programmer can move the servo to the programmed parameters in MANUAL test mode the servo(S) is not the problem.
The Programmer can be used to measure the TX output, check the Programmer manual for the how to…
Old 06-11-2006, 12:12 PM
flyrccg
My Feedback: (25)
I checked the TX and found my problem there.
servo: L-899,M-1498,R-2105
TX: L-1197,M-1498,R1797
Now I have to find out why.
