Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
HS225 servo arm??
Old 06-09-2006, 11:33 PM
WMB
Default HS225 servo arm??
Hi, I've got a couple off new 225 servos. They come with a big red servo arm. The arm is two different thicknesses. It would be ideal to use the outermost holes in the thicker arms, but my Sullivan clevises won't close down. They fit perfect on the thinner side. Who makes a clevice that is wider? Any reason for the different thicknesses?
One more. I'm building a Sig Kobra. Will one HS81 for each aileron be enough?
Thanks, MikeB
Old 06-10-2006, 08:59 AM
mglavin
My Feedback: (31)
Default RE: HS225 servo arm??
You might try Dubro's large stuff for GS models for a larger clevis.
I don't think HS-81 is a prudent choice. What does the manufacturer recommend? Possibly a mid-size would be viable such as the HS-225
