Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Optic 6 Heli Trim
Old 06-20-2006, 04:34 PM
dose
Default Optic 6 Heli Trim
I am currently using my optic 6 on my heli. but it seems that i need to trim the heli 3 times. One time in normal another in idle one mode and another in throttle hold mode.
is there a way to make it so that i only have to trim in one spot?
Old 06-21-2006, 12:29 PM
MikeMayberry
MikeMayberry's Avatar
Default RE: Optic 6 Heli Trim
That is normal.
Mike.
Old 07-09-2006, 12:40 PM
marked23
marked23's Avatar
dose,
One thing you can try is to trim everything in normal mode just how you like it, then transfer those trim values into your subtrim menu. Then you set all your trims, in every flight mode, to zero. If you ever need to re-trim, do it in the subtrim menu, and that will efffect all modes.
I never use my regular trims, mine are always zeroed-out... And a lot of other heli flyers do the same.
-Mark
