HS-422 v. HS425
WI
I am having many problems with HS-300 servos and am going to replace all that I have (12). What servo would you recommend so that I can fly with confidence?
Thanks for your help
The 422 and 425's are excellent servos and will hold up much better than the 300's. FYI: The 300's have been replaced by the 322's that use a much better pot so they will last longer. Send in the 300's for repair and they may be replaced by the 322's.
Mike.
Mike.
