Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
HPD-07RH receiver question
Old 06-30-2006, 01:07 PM
perreback
Default HPD-07RH receiver question
Hi,
I’ve got one (probably very stupid) question about Hitec’s HPD-07RH QPCM receiver. As far as I can tell, there is no way of knowing which way you should connect the servo leads to the receiver --- they fit equally well both ways. With the servo leads, this isn’t much of a concern (the servos will either work or then they won’t), but the same is true about the battery lead, and this is slightly more worrying --- isn’t there a risk that the receiver might be damaged if you connect the battery lead the wrong way?
Old 07-01-2006, 08:35 AM
mglavin
My Feedback: (31)
Default RE: HPD-07RH receiver question
Plugging the power pigtail in backwards will not damage the RX.
The signal wire is positioned "UP"...
