Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
SPLIT ELEVATOR SETUP?
Old 07-14-2006, 12:56 AM
chrome350
My Feedback: (66)
Default SPLIT ELEVATOR SETUP?
What would be the best way to set up 5955's on a split elevator? I have a Futaba 9Z and pcm receiver. Should I use separate channels for each servo and adjust with the radio, use separate channels and use the Hitec Programmer, or put the servos on a y-connector and use the Hitec Programmer?
Larry
Old 07-15-2006, 03:26 PM
mglavin
My Feedback: (31)
Default RE: SPLIT ELEVATOR SETUP?
Larry,
Utilize the 9Z's ailevator function which is outlined in the user manual. Separate channels are required.
Be sure and utilize HD gold plated quality servo extensions, switches together with a robust power distribution system.
