Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Multiplex mini IPD 9channel problems
Old 08-05-2006, 04:39 PM
Angus McDonald
Default Multiplex mini IPD 9channel problems
Just bought a new Evo radio with a mini IPD 9 channel receiver, is there some kind of magic to get the receiver to work? The transmitter is working just fine with my JR receivers but I cant get the servos to even twitch with the new IPD (non synthizied) did I get a dud? any help would be appreciated.
Goose
P.S. Receiver channel 22, transmitter channel 22, battery 1/2 charged approx.
Old 08-06-2006, 03:02 AM
mglavin
My Feedback: (31)
Default RE: Multiplex mini IPD 9channel problems
MPX crystal?
Are the servo connectors polarized corrrectly?
Old 08-06-2006, 08:39 AM
Angus McDonald
Hi Michael, yes it's a MPX crystal in the receiver and the yellow wire from the MPX servos is in the signal location. I've tried the servos in my JR receiver and they rotate fine I've also set up a plane using the MPX transmitter and JR receiver it also works fine, Hmmmmmm
Angus
Old 08-06-2006, 11:21 AM
mglavin
My Feedback: (31)
It’s not possible you have the modulation shift feature set for NEGATIVE shift with this model set-up is it?
Where are the ATV/End-points values set at? If there set to high the IPD RX will not honor the request and initiate HOLD. With the EVO TX 100% End-point is 60 degrees servo angle. Comparatively JR requires a 150% and Futaba 140% setting for the same travel volume.
All that said you may have a bum RX, it happens.
Old 08-06-2006, 12:35 PM
Angus McDonald
Michael, thanks for you helpful suggestions, I'm pretty sure it's a bum receiver. Positive shift is good and reduced all end point from 100% to 90% still nothing.
I'll contact Multiplex for warranty.
Angus
