Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
HFP-10
Old 08-17-2006, 06:18 PM
Torqued-Up
My Feedback: (16)
Torqued-Up's Avatar
Default HFP-10
My HFP-10 will not program some of my servos...
All servos are new HS5955TG's, purchased at the same time...
The HFP-10 has the v1.04 software installed...
The symptoms are that on certain servos, I cannot use the EPAneuFS or cw/ccw functions... When I attempt to select these options when certain servos are plugged, the programmer begins it's search function, then briefly displays are reverse-video bar, then goes back to the selected menu option... It does not allow you to set servo values...
Any suggestions would be appreciated...
Old 08-18-2006, 12:34 AM
mglavin
My Feedback: (31)
Default RE: HFP-10
I don't have an answer for you... I'd suggest sending the progrmmer to Service for a check-up. In some cases the updates do not take a set and Hitec replaces the unit free of charge.
