Hitec radio setup for BTE Delta
All my radios are Hitec and no complaints here but I do have a burning question. I just bought a BTE Delta Vortec plane and would like advice how to set it up. In radios I have a Prism and a Prism 7X as well as a Flash 5. I want to set it up with programmed elevon. Need a steerable nose wheel, also air brakes. The air brakes activate by toggling a switch and the twin controlled rudders both point inward - creating drag. Can I get there with what I own now. If so - how.
Thanks in advance,
Travis
Thanks in advance,
Travis
Oh boy... Well, you can get the elevon with all the radios and the steerable nosewheel and dual rudder would have to go on a double y-harness so you would not be able to get the airbrakes you want. You may be able to do it with the Eclipse but I would have to do some more thinking on that.
Mike.
Mike.
